Occasional slight "buck" / "miss"
Old 12-20-2017
11CoupeEX's Avatar
11CoupeEX is an unknown quantity at this point
As I cruise down the highway in my 2011 Civic EX coupe, every once in a while (maybe twice on my 20 mile highway run to work) I get this very mild little "buck" or what seems like a "miss". It goes away as quickly as it shows up. No engine light. At 65k I'm sure I'd be justified changing the coils and plugs, and I'd eliminate that possibility. I only notice it as I'm cruising on the highway and no other time. Always starts and idles fine and consistently. It seems like something electrical is failing very briefly, so maybe it is one of the ignition coils. Thoughts or experiences appreciated.
Old 12-20-2017
Wankenstein's Avatar
Re: Occasional slight "buck" / "miss"
Test coils before blindly replacing.
With engine idling slightly lift coil from spark plugs and listen for spark..lifting further from coil should cause drop in idle.
Do all four one at a time.
james_001
15
06-06-2012 11:06 AM
RemyL31
03-24-2011 07:09 PM
tpatru
09-17-2009 12:23 PM
SiG
06-07-2005 09:07 PM
Quick Reply: Occasional slight "buck" / "miss"
