2011 Honda Civic Power Window Not Working
Old Apr 11, 2016
fire331's Avatar
fire331 is an unknown quantity at this point
The rear right window does not work using the power switch or driver window panel switch. So far I've only ruled out the fuse which works because I switched it with the rear left window fuse and I've ruled out the window switch because I tried it on the other side as well and it worked. I'd like to check the wires in the connector that goes to the switch to see if there is power but I'm not sure how to go about it. Where could I get a wiring schematic? I have access to a clamp meter, but am I willing to go out and buy another type of meter if necessary. Any help would be appreciated!
Old Mar 17, 2018
DougAtoms's Avatar
DougAtoms is an unknown quantity at this point
Re: 2011 Honda Civic Power Window Not Working
I have the same problem. Right rear power window is inoperable. Did you ever find the problem?
Old Mar 18, 2018
mac25's Avatar
Dr Krieger of Modification
You probably have a broken whire from the master switch on the drivers door to that window.
You'll need to take off the door skin and check all of the wires for signal. Also check the motor itself by jumping it direct to a battery.
Hillel
Bolt-on Engine Performance
Mar 27, 2016 02:24 PM
mercerguy323
Mar 23, 2016 07:23 PM
jqnst
Feb 26, 2016 11:19 AM
Adam925
Feb 25, 2016 11:39 PM
Bobby Reynolds
Feb 6, 2016 07:50 AM
