Scanner reset TPMS. Does ECU need to learn now?
Old Jun 17, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
2010 civic 4dr lx
My Scanner reset the TPMS light. Does the ECU need to learn now or get ready? I need a nys inspection. do i go in the AM or do I need to drive 40mi first
thanks!
Old Jun 17, 2015
Re: Scanner reset TPMS. Does ECU need to learn now?
TPMS light will cause inspection fail?
If any sensor was replaced, it must be "learned" to the car.
The system does not automatically learn a new sensor by itself.
Each sensor has a unique ID#, and the TPMS system holds 4 ID numbers in memory.
If you have a sensor on the car that is not stored in memory, it will turn the light on.
The light will return in about 20 miles if a sensor has failed or if a sensor was not recognized by the system.
Old Jun 17, 2015
alex_nyc's Avatar
i didnt checnge anything, i just cleared a TPMS light and am wondering if that clear will interfere with my NYS inspection.
I know that if you disconnect the battery you drive a bit to get the ECU READY.
so does a TpMS reset make the ECU not READY?
Old Jun 17, 2015
So why was the light on? What code(s) did it have?
I don't know what your rules are.
This is for OBD2 readiness monitors. Powertrain only.
TPMS is not subject to the same rules and does not follow the same.
Old Jun 18, 2015
alex_nyc's Avatar
didnt have time to to get an inspection, but the TPMS light never came back. there was a lot of info but nothing worth remembering. I wast going to pay for that to get fixed anyways. code cleared and all is good!
I have to get more familiar with this $100 iCarsoft i990 Honda Scanner
Thanks Again for your help!
Old Jun 18, 2015
another no-DIY'selfer
deanaZoom
35
Sep 19, 2015 12:22 PM
OptimisticWay
Sep 18, 2015 09:37 PM
pfwel1977
Sep 10, 2015 02:16 PM
