2014 Civic suspension issues
Old May 27, 2015
edspyhill09's Avatar
edspyhill09 is an unknown quantity at this point
This isn't a question about upgrading the suspension, just OEM.
Front wheels:
When I roll over a road crack or shallow pothole at very low speeds the front end bottoms out and sounds like the engine is falling out. It is a solid bang conveyed through the frame. It also happens at higher speeds if I fail to see a break in the road surface. It sounds like metal to metal.
Rear wheels:
The rear wheels bottom out with loud thumping banging noises.
The car was bought in Oct 2014. The dealer I bought it from (J.L. Freed) always has an excuse why they can't look at it.
Do I have a lemon? Is it possible this car was damaged in shipment? Time to abandon Honda?
Ed
Old May 27, 2015
CraigW's Avatar
Re: 2014 Civic suspension issues
Find another dealer while you still have 3/36.
Old May 27, 2015
Going to a new dealer tomorrow. But does anyone have an idea what is going on? If this is how Civics drive, this is my last Honda. I was almost ready to buy a civic for my wife but not now.
Thank you,
Ed
Old May 27, 2015
Front wheels:
Rear wheels:
Ed
Old May 27, 2015
dariusld's Avatar
dariusld is an unknown quantity at this point
Slow speed bumps are smooth, but high speed, especially with passenger, sounds like it's bottoming out. I thought I was in my old lowered Honda. Just in the front though. I don't know if its normal or not. I don't drive that aggressive, so it hardly ever happens.
Old May 27, 2015
Check tire pressures first.
Waaay overinflated tires might generate a complaint like yours.
If you have to adjust pressures, make sure to reset the tire TPMS calibration before you drive it, or else you will get that tire pressure warning message coming on.
EDIT: Make sure your car isn't overloaded. 4 decent sized adults might max out the load capacity of the car.
If that doesn't solve your issue, find another dealership.
The car is under warranty, right??
While you are at the dealer, you might test drive another car like yours and see if it acts much different on bumps.
Old May 27, 2015
Also, in case anyone wonders why this thread reads funny, two threads have now been merged
Old Jun 12, 2016
Herrld's Avatar
Herrld is an unknown quantity at this point
Originally Posted by edspyhill09
Front wheels:
Rear wheels:
Ed
Ed, what was the resolution? I'm having the same issue. Linda
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
gabrown2
Apr 11, 2015 08:22 PM
SleepyT
Nov 1, 2001 04:59 AM
ImmortalEX
Oct 31, 2001 10:00 PM
