2007 civic coupe- leaking oil on incline
Old Mar 22, 2015
Thees1's Avatar
Thees1 is an unknown quantity at this point
Block cracked and new short block put in by dealer under recall. Now leaking oil in driveway and found out tech bent timing cover gasket when installing- put new gasket in-bring home and still oil leak- dealer puts on lift all day- I go and look and no leak- bring home and car parked in driveway on a nice incline and have leak again- can't tell where it is coming from- anybody with same problem or know what it is? Never had a leak in 8 years until new short block put in.
Old Mar 22, 2015
Re: 2007 civic coupe- leaking oil on incline
Is it losing any fluids?
If you have a leak, park over some cardboard (or white paper) so you can tell what fluid color is, and note carefully the positions so you can tell what area it should be coming from.
Go back and have them raise the car so you can see it too--before they have any chance to clean the mess off.
The only thing I can think of that makes a mess when doing these is power steering fluid might go all over the place when the subframe comes out.
Old Mar 22, 2015
Thees1's Avatar
Thx will check that
Runner88
Mar 2, 2023 04:54 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
ChristinaVHH
May 10, 2015 03:51 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
