2009 Honda Civic EX Coupe Firewall
Old Mar 16, 2015
ttyme19's Avatar
ttyme19 is an unknown quantity at this point
Ok... I'm gonna be the FNG here and ask but I cannot find an aswer to this anywhere ! I'm trying to run speaker wire from my trunk to my battery and I cannot find a hole in my firewall anywhere. I've looked at some posts/diagrams on here for other models of Hondas and tried to use those, but they don't apply.... I need help
Old Mar 16, 2015
Re: 2009 Honda Civic EX Coupe Firewall
Grommet just above the gas pedal assembly? Google found this post with pics:
http://www.8thcivic.com/forums/17437-post3.html
Fergawdsakes use a fuse at the battery, it really sucks watching your car burn to the ground because of an oversight like that.
Old Mar 16, 2015
ttyme19's Avatar
I've tried locating this one using this exact post.... lol Do I need to remove the carpet, or the fluffy stuff around the gas pedal?
Old Mar 16, 2015
It looks like you would pull down the carpet and there would either be a hole leading to the plug or there might be slits cut in the pad where the plug is and you pick out the padding at the cuts.
It looks like where a gas pedal cable would pass through if the car didn't have throttle-by-wire.
Here's another thread about installing an amp wire I found
http://www.8thcivic.com/forums/i-c-e...wire-thru.html
Looks like this one is run through where the hood release cable goes.
Old Mar 16, 2015
ttyme19's Avatar
Thanks so much for all your help ! I'm gonna try the second method and hope it works....
Old Mar 17, 2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
In my 2006 there was a hole only visible from the engine side.
Used a straightened out coat-hanger to punch through the carpet to see where it was on the inside.
The hole I found was a good fit for 4 gauge.
I dunno if you could fit 2 gauge in it or not, not sure what size wire you need.
I don't know how different then 2009 is, but here are the pictures from my 2006:
miatabro
Jul 17, 2015 12:12 PM
Pr0n1s
Apr 30, 2015 03:08 PM
LionSpratt
Apr 26, 2015 01:02 PM
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
