Part number for drive belt for 2007 Civic
Old Dec 27, 2014
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Was trying to do an online order for the drive belt for my 2007 Civic EX Coupe on CollegeHills Honda part fish. Under the alternator bracket, I see the belt as item 18 but see no part number or price. Anyone know where it is listed on a fish? Thanks
Vin.. 2HGFG12847H530848
site..http://www.collegehillshondaparts.co...cket-1-8l-scat
Old Dec 27, 2014
Re: Part number for drive belt for 2007 Civic
04301-RNA-307 (from bulletin 08-039)
EDIT
Also have numbers
56992-RNA-A03
56992-RNA-A03Y
Shown with "PS PUMP"
Belt is usually good for 100k plus.
EDIT again LOL: I'd go with the A03.
Old Dec 27, 2014
RIPSAW's Avatar
Thanks, 56992-RNA-A03 probably is correct. It cross references to the 2007 , the others , one list for $8.. and the other for up to a 2006 Coupe and later years for the Sedan. Thanks most important for the 100K + Hopefully will get back on the rear upper arm next week and take a hard look at the belt then.
Old Dec 27, 2014
A03 and A03Y both came up when I entered the A03 into the price check area of my dealer site....but the Y number doesn't show up in a catalog search at all.
I saw the super cheap price, I wonder what exactly one would get if they order that number? I wonder if it's something leftover from before the change to the updated routing? Meh. Too lazy to research it.
Old Dec 28, 2014
CraigW's Avatar
I have a 04301-RNA-307 waiting for my 2010 sedan. When I put that part # in at hondapartsnow site it say's it will not fit 2010.
Old Dec 28, 2014
That's funny. Catalog callouts can be misleading.
I bet the brand names on the various belts are the difference.
Saw this on various Odyssey applications from 05-10, like 3 different part numbers (and price$) but all 3 are the exact same size.
If you go to a belt manufacturers site (or a parts store) and look up 06-11 Civic 1.8 I think they should all take the same size belt. (Take into account the difference and updates for the 06 belt routing)
Gates: K070852
Old Dec 28, 2014
RIPSAW's Avatar
Sure it's not a 56992RNAA03.. Parts tec list it as 86 3/8" long..
Old Dec 28, 2014
What's this parts tec you speak of?
From the GATES site interchange application:
Honda 56992RNAA03 K070852
Effective Length (in) 85.21
Effective Length (mm) 2164
Number of Ribs 7
Outside Circumference (in) 85.75
Outside Circumference (mm) 2178
Top Width (in) .947
Top Width (mm) 24
Old Dec 28, 2014
Craig, does your 04301-RNA-307 have dimensions printed on the belt? Maybe a "PK" number, like 7PK2178?
Old Dec 28, 2014
RIPSAW's Avatar
http://www.importeccatalog.com/ShopB...20Belt&mode=PA
Old Dec 28, 2014
Seems to show a Gates K070855, which is a tad longer than the K070852
Belt / Sprocket Specifications Effective Length (in) 85.56
Effective Length (mm) 2173
Number of Ribs 7
Outside Circumference (in) 86.121
Outside Circumference (mm) 2187
Top Width (in) .947
Top Width (mm) 24
Old Dec 28, 2014
RIPSAW's Avatar
Is there a range marker on the tensioner to judge belt wear or stretch? Know on my CR-V, it started squeaking and you could see a little jerk with the AC on. Did not have a lot of miles on it. I got another at the dealer and thru the old one in the spare well. New one made it all well. The bando one looked a lot better than aftermarket. Had an old Mercedes my rich sister gave me that had a limit marker on the tensioner. Also had a $1100 fuel pump. Did not keep that one long.
Old Dec 28, 2014
Yes there is but I can't find a good pic for ya.
Just found in service info---
New belt length: Hydraulic power steering model: 2164mm
Found a pic of something
The pointer is near the hex where the left side of the red line is, and under the ear of the alt
Old Dec 28, 2014
RIPSAW's Avatar
2164mm=85.262...Thanks. I can see the pointer and the two range marker in you picture. Thanks.
Old Dec 29, 2014
CraigW's Avatar
Belt is at my house, will check later.
Old Dec 29, 2014
CraigW's Avatar
In white inkjet on the belt. 7PK2164 & 56992-RNA-A03
Sleeve has the other part # and the proper & improper routing diagram.
Maybe I got taken considering the # printed on the belt ???
Old Dec 29, 2014
RIPSAW's Avatar
i went ahead and got one. If indicator and belt looks good on inside with a mirror, will just put it in trunk. Seller told me he guarantees it is a OEM bando Honda belt.
Old Dec 29, 2014
Belt should be right for your car....and I'm gonna assume the number on the sleeve would also have been fine.
Bando or Mitsuboshi brands might be the difference? Didn't have any in parts to look at today.
I'd prefer either brand over the usual aftermarket offerings
LionSpratt
Apr 26, 2015 01:02 PM
