Need help finding VSS sensor
Old Dec 27, 2014
yknott's Avatar
yknott is an unknown quantity at this point
I'm trying to replace my VSS on my 2006 Civic LX (manual) because my speedometer stopped working. I was trying to follow the directions here: http://civic.hondafitjazz.com/A00/HT...821KBAT00.HTML
I've taken off the air cleaner (or at least moved it out of the way) but I dont see anything that looks like the sensor in the field of view. See attached pic
Can anyone point me in the right direction?
Old Dec 27, 2014
mikey1's Avatar
Re: Need help finding VSS sensor
what makes you think the sensor is faulty?
if the sensor is faulty your CEL should be on.....is it?
Old Dec 27, 2014
#6?
Old Dec 27, 2014
yknott's Avatar
Thanks ezone, that's the one. It looks like it's on the back side of the transmission. Can I get to it from the bottom? or do I need to completely remove the air filter assembly?
Mikey1: The CEL is on and the code read that the VSS was bad.
Old Dec 27, 2014
I have no idea, I've never had to replace one of those.
Probably faster for you to slide under the car and figure out if you can reach it.
You might check the wires real good, rodents LOVE eating wires.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
KillerX
Apr 9, 2017 08:20 AM
juror
May 26, 2015 06:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
