01 Civic LX misfire won't go away
Old Jul 28, 2014
dhg253's Avatar
dhg253 is an unknown quantity at this point
Exclamation 01 Civic LX misfire won't go away
My 2001 Honda Civic LX has only 97,000 miles. Bought the car and everything seemed fine. Got home from a 45 minute drive from said purchase, and car began overheating. Waited, then checked and zero coolant was in the system. Put coolant in and it kept overheating. Changed damaged thermostat - still overheating. Burped coolant system - temporarily stopped over heating for roughly two weeks. Did tune-up; spark plugs, oil change etc. Then, began the misfiring. A P0302 CEL code came on approx. a month after purchase of the car. Replaced ignition coil for the 2nd cylinder, worked for about a week. Then a multi-misfire code came in cylinders 2 & 3. Replaced ALL ignition coils, was fine for another week and a half. Then, code P0302 reappeared - replaced fuel injector. Now, no solid CEL but a flashing CEL appears when driving, and when its flashing it drives rough. However, the minute it goes away it drives slightly better, little stuttering. After each repair, when the car would be seemingly functioning normal, it still would occasionally overheat. Kind of feeling stuck as to what to do next. Any ideas or suggestions welcomed.
Old Jul 29, 2014
Re: 01 Civic LX misfire won't go away
Blown head gasket, plus very likely a warped cylinder head.
rcolosi
Apr 29, 2015 07:48 PM
Blaster30
Apr 22, 2015 12:21 PM
ashleymmackey
Apr 18, 2015 09:48 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
