95' civic dx idle problems
Old Dec 13, 2012
Hondafanatic740's Avatar
Hondafanatic740 is an unknown quantity at this point
having trouble with my 1995 civic dx with the b16. after starting when cold the idle is normal and drives fine. but after the motor warms up idle is low and aceleration is sh**. So i changed fuel filter,TPS,plugs and wires..seems to have helped about 50 % but still not running right..kinda stuck what to try next.
Old Dec 15, 2012
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: 95' civic dx idle problems
Just wondering, what weight oil do you use.
It seems as if your problems occur as the car heats up.. and that leads me to believe something is slowing down.. then I thought about how friction can cause things to move slower, and if the motor oil isnt properly lubricating things you may have that excess friction slowing your motor down..
Old Dec 17, 2012
i use 10w 30 yeah i mean i either have an oil leak or im burning oil..but its acting like its starved for fuel.. now cant even keep idle. so the problems gotten worst
Old Dec 17, 2012
go-part's Avatar
Former Sponsor
Check your fuel pump and the pressure regulator. It sounds like your troubles are fuel related..
Old Dec 18, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Oil is fine, 10w30 is fine, if the lack of acceleration was from friction because of no oil somewhere, yea the engine would have blown very quickly so that's not the problem.
+1 fuel issue. Check pressure to fuel rail, check injectors, hook up a scanner to check out sensors
Old Dec 19, 2012
z6freak92's Avatar
ek with z6 ... hmm why not
z6freak92 is an unknown quantity at this point
If u have a check engine light get it scanned and continue from there if u dont I would start with injectors take them out and try and clean the filters inside them with carb cleaner also u could have a sticky fast idle or iacv take the iacv off its behind the intake mani and clean it with carb cleaner make sure it dries before reinstalling same with the fast idle valve under throttle body
Old Dec 20, 2012
speedy25's Avatar
speedy25 is an unknown quantity at this point
IACV's are the problem on FI cars 99% of the time. Usually just some cleaning is enough to make your idle work correctly. A typical test to see if it works is to turn on the AC and see if the idle goes up.
-SP
Oil weight for an idle problem???!!! Thats a new one.
Old Dec 20, 2012
i am going to take off and clean the iacv see if that fixes the problem.. as far as bad fuel pump i dont think its the case still getting fuel..im starting to think its electrical more then mechanical.idk but thx everyone..ill post after cleaning the iacv
Old Dec 26, 2012
ok well update on this problem..took the distributer cap off and it had moisture inside. so replaced cap and roter spindle. ran better for a couple days but now it will stall out while driving and wont restart..was driving yesterday and it stalled out no spuddering or sluggish acceleration just died. im going now to try to get it back in my garage..seems to start a run fine for ten min. or so..its driving me crazy figuring this out..any input would be much appriciated.. thanks
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
