Where do I put a trans temp sensor?
Old Jul 20, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Hello everyone, I am looking for a transmission oil temp gauge for my car. I am seeing that the gauges have different ways of attaching to the transmission. Some have a sensor that would go in the pan (or case on a Honda trans), while others measure the oil temp from the cooler line coming out of the transmission going to the cooler. Which one do I want? I presume I want to measure the temp of the oil exiting the transmission since it will be hotter than the temp of the oil in the pan (or case). I have heard that depending on load, the oil leaving the trans going to the cooler can be significantly hotter than the "bulk oil temp", or the temp of the oil in the pan or case, which makes sense to me. So where would you suggest that I put the temp sensor? Thanks in advance!
Old Dec 15, 2019
Re: Where do I put a trans temp sensor?
To anyone wondering, what I decided to do is get a M18 x 1.5 to 1/8 inch adapter to screw the temp sensor into the transmission's drain plug hole. My logic for doing it this way is that the temp reading is pretty stable and takes a few minutes to change as conditions change rather than spiking up whenever I hit the gas like it would if I installed it in the line going to the cooler. While it would be nice in a way to know the temperature of the fluid in the torque converter, I decided that it would be too hard to know what the overall fluid temp is when it is going up and down all the time depending on load.
Old Dec 17, 2019
mac25's Avatar
Dr Krieger of Modification
Cool 😁
FoSho
Engine Swaps
Mar 4, 2007 08:44 PM
mugenman
Feb 6, 2006 11:30 AM
BlackIce
Aug 4, 2003 06:27 PM
Boilermaker1
Dec 19, 2002 07:46 PM
pothole
Sep 3, 2002 12:22 PM
