so what kind of guages to get?
Old Feb 1, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
ok i bought the speedo bezel awhile ago and i was looking at it 2night and i was thinking my interior is really stock and im gonna start doing some things and i know i want some gauges. im thinking im gonna go with a voltage gauge but idk what else to get. maybe a/f or oil temp? since this is my daily/show vehicle i want something practical. so suggestions are welcome
also is this in the right forum? if not mods go ahead and move it.
Old Feb 1, 2006
i'm getting volts, oil temp, and trans temp. now if i can only figure out how to install the trans gauge
Old Feb 1, 2006
mugenman's Avatar
lol yeah im leaning strongly towards oil temp
Old Feb 1, 2006
if you do, i'll let you know if the ebay vdo drain plug sensor fits in about a month. will make install very easy.
Old Feb 1, 2006
CustomXSpunjah's Avatar
CustomXSpunjah is an unknown quantity at this point
if you need practical gauges, you really dont need any honda equips all of their cars with the gauges needed to run
if you have a high voltage sound system go ahead and get a Voltmeter
if you have intake header and exhaust an air-fuel would be nice (if you must)
and oil temp is basically useless unless your boosted but you can get it if you want filler gauges
Old Feb 1, 2006
CenZ's Avatar
PWIT
i would go oil pressure, that was the murderer of my old car, reguardless it had 180k on it, but still. my car was runnin fine, then i looked down at my oil pressure guage(came on the cluster), noticed it was a bit low, was like eh, i can make it home only 5 minutes away. 2 seconds later BAM! needle dropped and blew 2 bearings
Old Feb 2, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
volt and a/f
Old Feb 2, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
A narrowband AF is worthless, and oil temp isn't useless, even with a stock motor.... especially when it saves your motor from blowing up. Not saying you can overheat the oil in traffic... but mine's read 271 before.
Trade oil temp for water temp. The stock gauge is a POS. Oil temp is a PITA unless you really need it.
Old Feb 2, 2006
TheSmuggler's Avatar
The Defi link meter will take care of everything you need ;-)
Old Feb 2, 2006
Jap-Euro Fusion
not everything.... they don't wipe my ***
Old Feb 2, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
a/f, oil, and wata
Old Feb 2, 2006
Okay NOBODY better get an air/fuel unless you want a broken car. I still can't believe people get/recommend these in this day and age.
Old Feb 2, 2006
lmfao my n00b friend tried to wire mine up and shorted out my engine harness
Old Feb 2, 2006
WilmncChris's Avatar
WilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of lightWilmncChris is a glorious beacon of light
If you get the oil temp or oil pressure its best to get the oil filter adapter from greddy. Takes about 10 mins to install. the adapter has 2 places for the gauges and also a place where you can run a oil line to a turbo. I have my oil temp setup that way. My oil pressure is running off a steel braided line setup.
Old Feb 2, 2006
Jap-Euro Fusion
Thats actually not the way you hook up an oil temp gauge. For it to register accurately, with the number that counts, it needs to be mounted submerged in oil, IN THE PAN. Otherwise its giving an intermediate reading, and not the static temperature of the mass of oil in the engine, which is what matters.
Old Feb 2, 2006
exturbo6's Avatar
what do me possible need to monitor with a intake and exhuast?
Old Feb 2, 2006
blouisgod's Avatar
Life Begins > 6800rpms
how do you hook up the oil pressure gauge? right now i have volts, vac pressure, and a a/f ratio gauge not hooked up just taking up space.
Old Feb 2, 2006
MajinB's Avatar
just cause you ran yours in series don't mean everyone else will. if you run it parallel then you should not have a problem
Old Feb 2, 2006
There is a good DIY on the site about how to hook up the oil pressure gauge. There is a pic of mine on my gallery. But the guy who did the DIY has a pic by pic layout. I think it took me about 2 hrs at the most to do.
Old Feb 2, 2006
i was never dumb enough to hook an a/f gauge up. but try it in parallel and tell me what happens a month later
Old Feb 6, 2006
oil temp doesnt need its own separate gauge unless your racing constantly. If your oil temp hits 300 or so in traffic theres something seriously wrong with your car
Old Feb 6, 2006
2K1Civic17"Gabe's Avatar
if you are non boosted/sprayed/or supercharged, none.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
ken4444
Sep 30, 2015 07:37 PM
rovafa2002
Sep 28, 2015 06:57 PM
