Vent Control Problem
Old Dec 11, 2014
Idayota's Avatar
Idayota is an unknown quantity at this point
I got a 2001 Civic LX. The vent control selector quit on me I believe because I only get air from the top vents and nothing from the feet or defrost. Being cheap I got a replacement from the junkyard(which was suppose to good) and it didn't fix anything.
So did I get a bad one or is there something else causing the problem?
Thanks,
Idayota
Old Dec 11, 2014
Re: Vent Control Problem
First step is probably to have the HVAC system do its self test and see if any fault codes are given.
Begin with the key OFF.
Turn the fan **** to OFF
Hold down the RECIRC and REAR DEFOG buttons
Turn the ignition switch to ON (do not start the engine)
Let go of the 2 buttons
Recirc button and rear defog buttons light up, then
Recirc button goes out in like 2 seconds, then AC light comes on....
Self test begins...
then shortly (maybe 10 seconds) the self test finishes and AC light goes out.
If there are codes the recirc light will now blink a code number.
If OK then the recirc light stays off.
Possible codes are numbered 7-15.
Then decide your next move
Old Dec 11, 2014
Idayota's Avatar
ezone,
Thanks. I got 11 blinks, so code 11, whatever that means.
Where do I find out that information?
Thanks,
Idayota
Old Dec 11, 2014
Code 11: Problem in the mode control linkage, doors, or motor
Could be stuck, jammed, broken, bad...Could be motor, linkage, doors, electrical
IDK from here but there's a starting point for you.
Seems like its time to get the service manual out.
Service manual thread, (no guarantees)...Look at the last page for the newest links:
https://www.civicforums.com/forums/1...e-updated.html
HTH
Old Dec 11, 2014
I might find the actuator and push/pull on the linkages while working the selector back and forth, maybe if it's just stuck that would free it up.
If no joy: Maybe remove it from the heater case, then see if the controller can operate it while not attached to the linkages on the case.
Old Jan 3, 2015
Idayota's Avatar
ezone,
Thanks for the help. It ended up being that the linkage came undone some how.
Idayota
Old Jul 26, 2021
Pricest3's Avatar
Pricest3 is an unknown quantity at this point
Self test begins...
What would code 9 be on my 2005 civic?
MyCivic
Electrical
Oct 28, 2021 11:06 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
crowtoo
May 11, 2015 06:50 PM
Microbiology
Nov 9, 2001 10:10 PM
