Wiring Hiccup
1995 Honda Civic Coupe. D15Y8. Si trans.
I bought my EJ1 4 months ago. About a week ago, it fried the ECU, the ECU fuse, and my srs fuse. I replaced all three yet the SRS fuse blows repeadtly. I also found out there was an alarm system wired completely wrong. I removed the alarm and speaker. Now it won't crank. Srs still pops. ECU is good. I've checked all grounds which are good. I have no fuel or fire.
I've replaced the distributor, alternator, head, all gaskets, iacv.
The rings are going out. Light blue smoke at start up then goes away. I run 91 in it. I went from a P75 to a P06 due to the P75 frying itself. Got to ride home in a fire truck.
There was previously cut wires under the dash. Off the ignition I see 5. Three of which run to a Relay? And orange and yellow wire coming out. There are no other hanging wires. The main relay assembly is good, but the wires running into it looked like someone tried melting them. I can hear the starter relay clicking when I try starting it. Clutch is engaged.
Nothing but issue with this car since I've had it. Bought it with a rebuilt D15B7. Si trans.
Re: Wiring Hiccup
Update. I rewired the relay back in and it cranks. Still no SRS. No prime or fire. Burned up the Q31 transistor on my P75 and just now my P06. Hard wired the SRS and it smoked and yanked it right out. Still had no fire.
I unbolted the fuse panel under the dash to make sure none of the wires where arching each other.
Anyone know what it could be? I'm ready to just part it out.....
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
