NEED HELP!! windows acting weird
Old Aug 13, 2010
slammed98ex's Avatar
slammed98ex is an unknown quantity at this point
Okay so i just got this civic a few weeks ago, and the other day i went to put the drivers side window up and it went about 3/4 the way up then started popping and not going any higher...any ideas?...Also when i got the car the passenger window just doesnt work, if i push either switch for it, what could this be as well?? ...if it helps i can take a video of the issues and post it??
Old Aug 13, 2010
02civicsi02's Avatar
Low and slow!
Re: NEED HELP!! windows acting weird
The driver side might be out of its alignment or something. So just take the door panel off and look in the spaces to see if you can see if it is. And the passenger side the motor could be blown or maybe the relay or something. First try spraying some windex on the switches and see if that works or not. Plus does your car have a passenger side window look over on the driverside?
Old Aug 13, 2010
okay ill take a look tomorrow morn..if its out of alignment is it easy to fix or should i take it somewhere? ..what would the windex do? and nope no window locks
Old Aug 13, 2010
Low and slow!
Its an easy fix just take the bolts off of the parts that holds the window and put it back in palce then bolt the parts back up and try that. And the windex sometimes can help wires and stuff. My buddies mustang driver window stopped working one day and we did that and it worked lol.
Old Aug 13, 2010
okay thats easy...hahaha wow that would be convenient if it works =P..ill check all the fuses and relays too
Old Aug 13, 2010
thanks for the help bro, this forum is awesome , my old Fbody site the ppl sucked they never helped if u had a problem id post something asking for help and a week would go by and no replys
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Rexall
Sep 11, 2015 02:30 PM
Dave Brabant
Sep 9, 2015 08:11 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
