Amp's power protection kicks in when connected to sub
Old Jun 13, 2010
mrdigital's Avatar
mrdigital is an unknown quantity at this point
my amp is a denon dca-800 i found on that the L/R sub channels are 100W each
and my sub is a 225W MTX 10" . 4 Ohm so i wired the sub in bridged mode to the amp so i get 200W to the sub on 4ohm how ever the amp shuts off any ideas? it works fine on 100W but not in bridged.. could the amp or sub be ****ed up?
Old Jun 14, 2010
electric130's Avatar
Re: Amp's power protection kicks in when connected to sub
DVC sub?
Old Jun 14, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
How are you wired to the speaker. If it a 4 ohm and not adjustable then you should have only 1 set of Pos and Neg plugs. If it is a Duel voice coil then it will have 2 sets.
Make sure you are hooking the speaker up right after you bridge the amp. If you dont then it will sent a 2 ohm signal back to the amp and kill the amp to save the speaker.
Old Jun 30, 2010
kgflash1's Avatar
kgflash1 is an unknown quantity at this point
dont bridge a 100/200 watt amp. if you ant more power upgrade your system a tad bit. either way, your amp and subs at 100watt seem to both be 4ohm and 4ohm stable. if your am is 2ohm stable as well maybe buy another sub of the same type and wire them in parallel.
Old Jun 30, 2010
Drenic's Avatar
Drenic is an unknown quantity at this point
I had that problem b4 I had to upgrade the amp and also how are you bridging the the two subs to the amp (make sure you dont bridge the subs to one channel). This will cause the amp to overheat and cut off.
wishihadavtec
Jan 6, 2002 07:33 PM
Mary
Jan 2, 2002 06:42 AM
PimpBot5000
Nov 26, 2001 07:15 PM
Slickwillie
Nov 19, 2001 02:48 PM
2k2CivicEX
Nov 5, 2001 07:22 PM
