question before I buy tonight.
will it be ok you buy this amp to power my 4 cabin speakers. I know that my speaker can hadle the power
(all infinities) I just want to check with you guys to make sure it is the right choice. It's the 414X.
414x
414x
I'm not sure about the specs for the Infinitys that you have, but i think that it should be good. Too much power is much better tahn to little. And about the 5-volt pre-amp outputs... very good [IMG]i/expressions/face-icon-small-smile.gif[/IMG] that should work beautifully [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
The Standard One
it's perfect for 6.5's but it's a little weak for 6 x 9's(weak meaning you can't push it to their max, but ey it's less likely for your speakers to blow this way...)... it should be fine tho. if i had infinity's i would probably get the same watts as that...
vtecbrah
19
Jun 5, 2015 09:38 PM
zack22490
Apr 29, 2015 03:17 PM
