Broken wire to power windows?
Old May 15, 2010
miggitymark's Avatar
miggitymark is an unknown quantity at this point
I just bought a car that had no power to the power windows. The motors were disconected, and I cant get power to the master switch. I do have power at the fuses though.
My problem: I can't find where the wires go into (or out of) the fuse box. It's just too crowded in there for me to see where they go. The service manual only mentions the floor harness (c556) but doesnt show its location.
Can anyone tell me which connector it is out of the fuse box?
Old May 15, 2010
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
Re: Broken wire to power windows?
check the power window relay. if it's removed it diables all windows. dont remimbe witch one it is though. might be in the hood or dash fuse box
Old May 16, 2010
...one step ahead of you...
all fuses and relays work, and I have voltage at those fuses. I dont have voltage at the switches though.
Is there a way to take off the rubber boot that covers the wiring between the door and the body? or is there a way to disconnect the wiring from the door? it's covered in electric grease in there
Old May 16, 2010
vanser3004's Avatar
vanser3004 is an unknown quantity at this point
Actually I don't believe that it's broken wire or something - if there are not working all power windows - there should be at least several broken wires. At your under-dash fuse box check wires that run to the Master switch for power right on connectors. It's easy to get access to the under-dash fuse box wire's connectors, just unscrew the bolt on the right side of it and pull it down, it should slide down.
I think most likely you have bad connection at under-dash fuse box (check them) make tighter connection by bending it with little screw-driver. If there are no power on them could be problem with fuse-box.
Old May 17, 2010
CraigW's Avatar
What year and body style is this ??
Old Aug 24, 2010
indiggio's Avatar
indiggio is an unknown quantity at this point
Did you ever resolve your problem with a suspected broken wire?
I'm having similar issues with just my passenger side window. All others work, and I've replaced the regulator and switches. Now I'm thinking it's a broken wire somewhere.
I suspect the break is inside either the driver or passenger boot as they get the most movement.
Thanks
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
MamaBear2015
May 3, 2015 02:17 PM
