Having problems with fuses? Or other?
Old Feb 3, 2010
Hookums's Avatar
Hookums is an unknown quantity at this point
Hey guys, I've been reading through the forums and I couldn't find anything on this,sorry if its already been covered or my problem is blatantly obvious or anything.
Here's how it goes...I was using a splitter on my cigarette lighter, and I put a 3way splitter to it, and it turned off, so I was a little peeved, and simply replaced the fuse, and went back to the two way splitter, no problem. I then realized when I blew that fuse, my front passenger, rear passenger, and rear driver side windows all do not work, but the fuses are fine. Also the horn stopped working, and that fuse is fine, and my heater is inconstantly warm, like even when the car is warm it will sometimes spit out warm air or spit out cold air.
I'm really lost and I honestly am not much of an electrician of any sort, so I had no idea where to go from here. Any help is appreciated, thanks guys!
Old Feb 3, 2010
Re: Having problems with fuses? Or other?
prolly easier to check all the fuses at once rather than guess which one blew. there is a fuse box under the hood and also under the dash above the gas pedal. it could be a backup fuse that blew.
Old Feb 3, 2010
CraigW's Avatar
Check your window lockout on the master switch.
If your horn is not working... you may want to also check your brake lights.
Check your coolant level.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
steveneddy
May 19, 2015 02:39 PM
