Head Lights
Re: Head Lights
do the hi beams work? if not theres your problem. DRL uses hi beams at 1/2 power (wired in series) so they run at less than normal brightness. do you hear any kind of buzzing in the dash? could be the relay went bad, or a fuse, or the actual drl module behind the kick panel where the hood release is.
Re: Head Lights
Hi,
Thank you, I already check all the fuses both under the hood and the underneath the steering wheel and they are all good. One thing I notice though is that the DRL light is keep on lit.
mike
mike
Re: Head Lights
check the drl control box under the driver side kick panel by the hood release lever. you might need to take it apart and check for loose connections.
SpoonSportsD17
Nov 29, 2001 02:02 PM
