ground wire kits
Old Jan 7, 2009
Shadow619's Avatar
Shadow619 is an unknown quantity at this point
Post ground wire kits
do ground wire kits actually help? I saw a kit on another site and was wondering if theyre worth buying.
Old Jan 8, 2009
electric130's Avatar
Re: ground wire kits
they helped some with lights dimming, but the main thing is that if you have any kind of system. our stock grounds are ~5.5ga (15mm^2 metric gauge) i put 4ga on mine. if that 15mm^2 cable is designed to handle the car's load, any additional load you put on it will need bigger cables. i think it's funny when people put 4ga, 2ga or 1/0ga power cables on their amps and then leave the stock ground cables on the battery. where ever your smallest cable is, that's your power bottleneck.
Old Jan 8, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Buying? No.
Making? Yes.
Just pick up some 4 gauge wire, some ring terminals and replace them yourself.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Lopes101
Jun 7, 2015 08:04 PM
dinsum
May 28, 2015 09:30 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
blackbullet
Dec 1, 2001 03:44 PM
