Major Problem???
Old Apr 9, 2008
PsiCivic's Avatar
PsiCivic is an unknown quantity at this point
Unhappy Major Problem???
i have a 89 civic hatch and i went to my car and my battery was dead and its a new battery... so i noticed that the tail lights stay on even though i turn off the lights and i cant figure out why? can someone plz give me detailed help on some ideas on how to fix this cuz it wont hold a charge therefore i have no HONDA!!!
thx guys
Old Apr 15, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
Re: Major Problem???
Take the battery to an auto shop (like Autozone, etc...) and get them to test the battery. Also, check the terminal connections for corrosion and make sure they are on right. Hope that this helps!
Wagner
Old Apr 22, 2008
RFlum's Avatar
RFlum is an unknown quantity at this point
Thumbs up Re: Major Problem??? I doubt it....
I had the same problem a couple of weeks ago. I've got an '88 Civic. I hope you have the same solution I did.
On mine, the brake light switch had gone out of adjustment - only took it 20 years..... It's easy to fix. Under the brake pedal arm there's a button push-switch. It has an adjusting nut. Loosen it, adjust the button AWAY from the brake pedal arm. Tighten it.
What's happening is when you release the brake, the arm is supposed to back away from the switch so it comes out to the OFF position. If it is too close to the arm, it never opens enough to break the connection to the taillights.
This ruined my battery, draining it down to nothing 2 or 3 times until I figured it out.
Good luck! Rob
Jon-Ohio
Jun 30, 2018 08:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
