HID Help?
alright well i know a guy who has and srt and he got hids for the car and explainede to me how it worked and how he installed it with a ballast and all those different kinds of things for it to work safely(w/o catching fire)...anyway i really liked the look but did not like the installation process or the price for hids so whats the next best thing???
i know people will say get the silverstars at autozone..but that to me just seems like a cheap product coming from autozone...so what should i do??? any product suggestions??
Re: HID Help?
silverstars are on clearance at target for $14 right now. anyway HIDs are EXTREMELY easy to install. you give it a power wire, ground the other, and just plug all the wires that it comes with together. its extremely straight forward.
Re: HID Help?
still easy. read up.
http://www.bcae1.com/swrelay.htm
https://www.civicforums.com/forums/2...ay-wiring.html
Re: HID Help?
no actually, boosted halogens (catz zeta) does not require a wire upgrade. it takes in as little as 11v and outputs 15.4v so everything is up-converted by the box. this means that stock voltage is still running through the factory wires before reaching the zeta ballast. i tested this with a multimeter. now if you are only using hi watt bulbs, no zeta, then yes it will draw more power through the stock wires and requires harness upgrade. and yea boosted halogen is nice if you cant get hid. after using it, you will wonder how you ever drove without it. it makes the stock lighting acceptable.
Re: HID Help?
stock volts ~12
stock watts ~55w
equals 4.58 stock amps
if bulb got 4.58 amps at 15.4v, then boosted wattage would be ~70.5w
if the ballast was at least 90% efficient (may be less than that) it would take ~6.53amps per ballast at 12v. the lower the voltage at the headlight, the high amp draw needed to reach the 15.4v for a given current at the bulb.
without knowing the exact manufacturer specs or taking some amp readings, it's hard to say exactly what's going on. we need amp readings though, not voltage.
Re: HID Help?
hmm i see what you mean. but i have been running this setup for quite a while and a few times with over 4 hrs continuous use. the stock wires do not feel hot or anything (altho the connector and headlamp housing is waaay hot lol). and yeah your 70w calculation seems to be accurate considering the brightness increase. now one thing it warns is not to use higher watt bulbs with the ballasts (altho i know people that are and still have no problems). considering this thing was made in japan, i feel a bit better that it wont catch the car on fire lol.
Re: HID Help?
well, the high beam pulls 65 watts, so 5 more shouldn't hurt it. as you know, the high and low use the same power wire. i'd like to think that Honda left a little wiggle room in their wire sizing......
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
