alarm brain dead?
Old Jul 20, 2007
blinknfgkicks's Avatar
blinknfgkicks will become famous soon enoughblinknfgkicks will become famous soon enough
alarm brain dead?
i just installed my 2-way paging alarm and when plugging the battery back in, nothing stated to work. i plugged the power and ground wires directly into the battery along with the LED indicator light and nothing comes on at all. Im guessing its a defective brain, is there any other ways to check if this thing works? or is it dead?
Old Jul 21, 2007
mneuls's Avatar
mneuls will become famous soon enoughmneuls will become famous soon enough
Re: alarm brain dead?
is this a bulldog security one by any chance?
Old Jul 21, 2007
no
its a fox fai-8200
Old Jul 21, 2007
i plugged all the wires in for the alarm included the door triggers and stuff and nothing came on when i plugged the battery back in. so i plugged the power and ground wire directly to the battery just to see if the unit was getting power, and the light wouldn't turn on.
here is the wiring diagram
http://alarmsellout.com/support/f-82...ng-diagram.pdf
what is the minimum i would have to plug in to see if it is still functional?
Old Jul 23, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
This one is kind of tough to troubleshoot. To be honest I have no idea but the LED for the alarm may not come on until it's armed. So maybe you have a bad remote and that's the problem. Or maybe the antenna isn't plugged in an all the way, or the cable is backwards. I don't know much about this brand so I can't be too much more specific.
An alarm by itself is really difficult to bench test. You would have to power up the unit, confirm an arm via the LED, and then apply the appropriate signal to whatever door trigger while watching siren output with a meter. But this is just one thing you could do, there are lots of ways to test it on the bench but it's not too easy in general.
Not sure if any of that helps but maybe it will get us to some other more useful solution.
frank_kleng
Sep 29, 2015 10:55 PM
Skunkone
Sep 24, 2015 04:38 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
First Car
Sep 8, 2015 08:54 PM
