Notices
Wheels and Tires Post your wheel and tire related questions here.
2010 Honda Civic - TPMS light
Old Jun 15, 2020
Jperry10's Avatar
Jperry10 is an unknown quantity at this point
Hello all,
I am a bit confused and annoyed, would appreciate if someone could help me. I went to monro today because I was having an issue where I was filling air in my tired between 1-2 weeks then the low tire pressure light would come on. I found out that my sensor was broke and the valve was broke as well. They fixed them and everything seemed to be fine. A few hours later the TPMS system light came on and took it back in. They looked at it and apparently retaught all the tpms sensors. The system told them to drive it and it should clear off itself. I got a second opinion from two Honda dealerships and a YouTube video saying more than likely the light won't go off by itself but there's always the possibility. Just wondering if its possible in like a day or two if this light will actually turn off itself or if I am dealing with another issue? Any input or comments are appreciated, thank you in Advance.
Old Jun 16, 2020
BrotatoChip's Avatar
Super Moderator
Re: 2010 Honda Civic - TPMS light
Have you actually checked the tire pressure? Make sure it's the same as the other tires.
Old Jun 16, 2020
Jperry10's Avatar
When I brought it back in to that shop they checked all 4 tires for there pressure. To the left of that light is the actual low tire pressure, that there is apparently for the monitoring system. Which is why im confused why the actual system would have an issue all the sudden.
joenobodyyet
Electronics
Dec 14, 2018 12:07 AM
wharton57
Oct 23, 2018 10:09 AM
Man In Black
Apr 28, 2017 07:00 AM
Mantaray14
Jan 3, 2012 04:58 PM
02EXCoupeGuy
Nov 4, 2002 12:20 PM
