TPMS busted
TPMS busted
Hi all,
I have a 2010 Civic EX series. I overinflated the tires close to 40 psi and drove around that way for weeks. The tpms light came on so I checked the tires and deflated them to whatever was on the door 34 or so. This was a few months ago and the tpms light is still on. It never really went off since.
Is it true I can reset this by deflating the tires? I'm sick of looking at the light!
Thanks,
Rick
Thanks,
Rick
Re: TPMS busted
No. You can't do a darn thing with it.
Is the car still in warranty? Go to the dealer. Duh.
Is the car out of warranty?
You are still going to the dealer.
Most independent shops won't have an HDS scanner (or an equivalent) to access the system unless the shop specializes in Honda and is extremely well equipped. Call and ask before bothering to waste your time. They are out there, but few and far between.
40 PSI will not turn on any light.
The butt icon (_!_) comes on with low tire at about 27 PSI and lower. It will also come on at 51.9 PSI and higher.
The "TPMS" light on means the system has a problem, usually a dead sensor. There should be a code set in the TPMS computer.
The TPMS light will also come on if a tire is missing, like you had a flat and put the spare tire on. System needs reset if that happened. I'm not positive that will happen on its own though. May need the scantool to do the reset.
Did you have any tires replaced? It has been common for rookies everywhere to break sensors when dismounting and mounting tires.
I have seen tire replacers break a sensor, then replace it, and not be able to program it to the car. TPMS light is on because the car doesn't recognize the new sensor.
Good luck getting someone to admit fault after "This was a few months ago".
Did you use Fix-A-Flat in a tire? Green Slime? That stuff ruins the sensors in a hurry. You own it.
Re: TPMS busted
Any dealer around here is going to charge me at least $150 or more to reset this stupid sensor. My car is over a year old and out of warranty. I did get a flat once, don't know if that caused it, but there must be a way to reset the sensor without spending that kind of money?
Re: TPMS busted
Sensors are covered unless someone else broke it and it can be proven....play dumb.
We warranty most of them anyway for good customers.
You are stuck with a dealer anyway unless you can find a shop with an HDS scanner.
WTF makes you think it will be $150 just to check it?
Get on the phone and ask.
We sure don't get that amount. It's free to the customer if warranty covers it.
If the TPMS light was on because you had a flat tire, it should have reset itself. (p 272 in your owners manual.)
If a sensor is bad, they should prove someone else caused it before they can make you pay. Bad sensors are somewhat common.
Re: TPMS busted
I'm in NY. You really don't want to be dealing with any dealers or mechanics in general unless you are ready to drop a few hundred for the smallest of problems. I really can't see spending tha much for something as menial as a tire inflation sensor. I could probably purchase and replace all four sensors for what they would ask.
I thought they told me the warranty was only 12 monthsfrom date of purchase. I'll have to take out my bill of sale and look at the fine print. I'm pretty sure that was deal though.
Thanks,
Rick
Thanks,
Rick
Re: TPMS busted
Thanks,
Rick
Thanks,
Rick
MANUFACTURERS' WARRANTY, not the dealers warranty.
Only a few things are 12/12 warranty. Wear items are 12/12 (brake wear, wiper inserts, etc.).
TPMS is covered under the 3/36, the bumper to bumper warranty.
Powertrain is 5/60.
It's all warranty unless there was abuse.
The sensor I.D. #'s still have to be "learned" to the car, dealer level scantool is required to do that before they will work.
h4ldol
Electronics
28
Aug 25, 2019 07:04 PM
h4ldol
Apr 24, 2017 08:16 PM
Balkos
Sep 11, 2015 11:39 PM
