Notices
Wheels and Tires Post your wheel and tire related questions here.
Tire size
Old Dec 6, 2010
Funktion81's Avatar
Funktion81 is an unknown quantity at this point
Tire size
I need to buy some winter tires my current size on my '05 civic is 185/65/R15.
The winter set I'm looking at is 195/55/R15, will I have any issues installing these? -Thanks in advance.
Old Dec 6, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Tire size
They can be installed but the general rule of thumb with winter tires is the skinnier, the better. Your looking at a wider tire there that won't perform as well in the winter. It's not really a good idea to deviate from your OEM tire size, though it can be done.
Old Dec 6, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Tire size
The main issues you will have is the speedo will read 4.2% too fast. So when you are 57.5 your speedo will read 60.
The other issue you may encounter is very slight rubbing on a hard turn. More annoying than anything unless you are running chains or cables. You would have to be more careful.
As far as the width difference, the 10mm isn't going to make much difference. You should be OK with them for the winter months.
Old Dec 6, 2010
MindBomber's Avatar
Live for the Twisties
Re: Tire size
There won't be any rubbing issues, thats the exact same size I have installed currently. Generally you can go up or down 1 size without experiencing any issues.
On snow tires you should use the smallest possible tire, because that way the tire will encounter the least possible resistance cutting through snow and ice. I haven't had much of an issue in snow with mine yet though.
Old Dec 8, 2010
Funktion81's Avatar
Re: Tire size
Thanks for the replies!
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
