Notices
Wheels and Tires Post your wheel and tire related questions here.
trying to replace wheel bearing, not coming out
Old Oct 5, 2010
mecheng101's Avatar
mecheng101 is an unknown quantity at this point
So, I'm replacing the CV joint and trying to replace the wheel bearing while I'm in there. The bearing will not come out. The bearing is now in two pieces, one piece attached to the hub and the other still attached to the car.
I've tried pounding it out, soaking it in WD-40 and liquid wrench, nothing is working. I took off the retainer ring, so all that's left that needs to come out is the outermost ring of the old bearing (seeing as the rest of the bearing is still attached to the hub - any suggestions on how to get that of too?) but it will not budge.
Any suggestions? It's a 94 DX coupe.
Old Oct 20, 2010
chuckklr04's Avatar
chuckklr04 will become famous soon enough
Re: trying to replace wheel bearing, not coming out
Heat the outside and cool the inside if possible.
Old Oct 20, 2010
02civicsi02's Avatar
Low and slow!
The wheel bearing has to be pressed out with a press and also has to be pressed in with a press.
Old Oct 20, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Old Oct 20, 2010
Low and slow!
Originally Posted by Nosepicker
Why are you confused
Old Oct 20, 2010
Nosepicker's Avatar
So, basically what you're saying is one cannot do this alone without a machine press?
Old Oct 20, 2010
Low and slow!
Yes you need a press to do this. It says it in the service manual and what do you think they use at shops to replace a wheel bearing, a press of course. I have replace countless wheel bearings at the shop at school and you have to use a press to do it. If you try doing it with your hands or tools have fun. You might get it but its going to take a very long time. It would be a real pain trying to get the bearing back in to. You need a special tool also for the snap ring to.
Old Oct 20, 2010
Nosepicker's Avatar
Good info. Glad I read this before tackling it. Thanks OP, but sorry about your situation at the same time.
Old Oct 20, 2010
Low and slow!
Just a quick tip, before you put the new wheel bearing back in slather it in anti-seize and oil. It makes it go in so much easier and makes its spin really good to.
edgenet
May 2, 2015 08:00 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
