Notices
Wheels and Tires Post your wheel and tire related questions here.
handbrake issues
Old Nov 30, 2009
pinkyboy's Avatar
pinkyboy is an unknown quantity at this point
Unhappy handbrake issues
hi there,im having real probs with my fathers civic 1.5 aerodeck,earlier in month put it in for mot,it failled on brake pipes,front brake discs,and few other things,put new pipes on it,new discs on front,and 2 new calipers on rear,new pads all round,put it back in,it failed again,on uneven handbrake,holding on one side but not good on other,tried taking it off again and putting pistons in to level off but still not right,anybody help before i have no hair left!
Old Nov 30, 2009
Re: handbrake issues
did you check the adjuster cables where the hand brake is? usually it lets you adjust the tension on each side.
Old Nov 30, 2009
pinkyboy's Avatar
Red face Re: handbrake issues
hi,you can only adjust both at same time,its central if you no what i mean,no way of adjusting just the one side,could it be brakes needing bled again?would that cause that to happen,its a 1998 civic aerodeck,1.5 vtec e,gratefull for any advice!
Old Nov 30, 2009
you might try bleeding again, or adjusting the cables separately for each rear brake setup. im unfortunately not too familiar how the hand brake works with rear disc brakes.
Old Nov 30, 2009
pinkyboy's Avatar
im going to have another go tomorrow at bleeding them and see what happens,thanks for the help.
PiCASSO
Apr 23, 2002 12:38 AM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
droidekaus
Mar 18, 2002 02:06 PM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
