Notices
Wheels and Tires Post your wheel and tire related questions here.
brake pedal to the floor???
Old Jun 12, 2008
babyontheway's Avatar
babyontheway is an unknown quantity at this point
Hey everyone,
I noticed that when I have the AC on, my brake pedal goes to the floor, as if i am loosing brake oil or something. When I stop at a light, i feel I need to pump the pedal many times to get the car to stop.
the hand break is strong and the car brakes normal without the AC - WTF?
civic 96, si
thks for all your help in sheding some light on the issue -
Old Jun 12, 2008
TRIZ's Avatar
Re: brake pedal to the floor???
I never heard of that before...
Old Jun 12, 2008
i even checked the brake fluid and it is maxed. i really can't understand.
Old Jun 12, 2008
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
i had a simmalar problem in my 4th gen. i ended up replacing the master cylender b/c it would leak and it would slowly sink to the floor w/o the a/c but with it would go down to the floor and just b4 it would hit it would stop the car.
replace the master cylender. worked for me
Old Jun 12, 2008
yeah at first i would say the master cylinder but it might also be something wrong with the power brake booster.
Old Jun 13, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Whoa, I donno, but get it fixed fast, that's important!
Old Jun 13, 2008
I will have it checked next week and will keep you updated
thks for your help
GB
Old Jun 13, 2008
Zzyzx's Avatar
Autocross Junky
Brake booster... or simply a cracked vacume line. Considering it only happens when the AC is on.
Its probably a good time to replace all of your vacume lines any way.
Old Jun 13, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
+1 on the vac line. The brake booster works by making a vacuum between the pedal head and the master cylinder. Something is happening when the A/C is on to make the vacuum not work, probably a leaking hose somewhere. Get it fixed, I don't want my injury risk higher knowing that there are people knowingly driving on roads with bad brakes...
juror
Suspension DIY
Jul 30, 2019 03:28 AM
wootah88
Jul 21, 2015 10:22 AM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
