Notices
Wheels and Tires Post your wheel and tire related questions here.
Carr streering wheel pulls hard to the left or right
Old Mar 23, 2008
carter's Avatar
carter is an unknown quantity at this point
When driving after I installed the rims I will suddenly while slowing down or accelerating feel the wheel pull to the left or right. Its not uncontrollable but its weird having to fight that randomly now and then.
Could it be the allignment? Or the wider tire is just more sensative to more bumps and grinds on the road?
Old Mar 23, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: Carr streering wheel pulls hard to the left or right
That's a wheel balance issue. Same exact thing happened to me when I got my wheels from wheelsnext.com makes me wonder if they even balanced them before they shipped it out. Geez....
To fix it, you have to take it to a tire shop and have them balance it. Pretty cheap usually, if you have an america's tire near you, you can tell them that you bought the tires through them, and they'll do free balancing for you.... Don't know how much it usually cost to balance... I know that america's tire charges like 15 bucks for mounting AND balancing. whatev.
In then mean time:
If you have directional tires, start with the front driver wheel, switch it with the rear wheel. If it still does it, take the passenger side wheel, switch it with the rear wheel, If it still does it, then that means two out of four of your wheels aren't balanced.
If you don't have directional tires, try to rotate the wheels to the front two wheels are the ones that are balanced.
Old Mar 24, 2008
ex-cobalter's Avatar
ex-cobalter is an unknown quantity at this point
When a rim is shipped pre-balanced, it loses that balance the moment the tire is installed. The wheelsa all have to be rebalanced to make sure it spins right, because even though the rim is perfectly weighted, the tire isnt.
With my civic, i know it is an alignment issue, because the steering feels way too loose, and i am all over the road @ hwy speeds.
Old Mar 24, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
double posted
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
HiImBrandon
Jun 1, 2015 07:34 AM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
