Notices
Wheels and Tires Post your wheel and tire related questions here.
Fitment Issues 225/45/15 Help!
Old Oct 2, 2007
Boggie6868's Avatar
Boggie6868 should not be trusted
Hey everyone,
Let me give you all the specs before I try to explain what I'm going to do.
15x8 +36 offset
If I have 205/50/15 Azenis on those rims, I have 4mm of clearence on the inside of the wheel to the springs. When the wheel is fully turned I have 4mm of clearence to the control arm.
Now I'm trying to fit 225/45/15 tires on the 15x8. The overall width difference from the 205 to the 245 is 8.2" to 8.9" respectively. So thats roughly .35" on added to the width on both sides. In mm thats rougly 8.4mm on both sides. Since I don't have enough clearence I decided to get some spacers(only 4mm). The ones I picked up are 7.5mm spacers. The spacers should push the inside clearence from 4mm to (4mm+7.5mm=11.5m) 11.5mm. Seeing as how the tire needs 8.4mm the 11.5mm with the spacer should work.
Is the good or is this bad? Is it bad to have the tire stick out of the fender?
Old Oct 2, 2007
Boggie6868's Avatar
Re: Fitment Issues 225/45/15 Help!
Can a mod move this to the 7thgen section? Thanks
Old Oct 2, 2007
greeen01civic4d's Avatar
that is a whole lot of tire, if u went to a 215/45/15 u might have less problems, but spacers tend to make wheel bearings go bad faster than usual, and can have problems with fenders rubbing at full turn, but its up to u, but legally, u technically cannot have any tire showing outside the fender
Old Oct 2, 2007
Alpha 5's Avatar
Yes, when the wheel sticks out of the fender it earns you a seat on the Ricer Thread. It also puts too much strain on the suspension. You will have issues.
Old Oct 2, 2007
Boggie6868's Avatar
Well I bought the 225/45/15 because they were on sale for 53 dollars a tire. Not to mention they are R compounds. The set of rims I'm mounting these on won't be on the car daily, these are my autox and track day rims. I also don't plan on having the car lowered enough so that it rubs. And I do plan on getting longer wheel studs if need be.
Btw please don't call me a ricer, I'm going for the largest contact patch I can achieve with 15x8s.
Thanks for the replies, however the question still remains. Will they fit? I don't care about sticking out, its more of rubbin in the inside of the wheel well.
Old Oct 3, 2007
dscottb01's Avatar
From: Scott County, KY. Where else? This is my town! Na na na..na..na..
dscottb01 is an unknown quantity at this point
With tha kind of offset, I would say no. Not without spacers and longer front studs. The rears may be okay. With the MAC susp up front, my 225/45R15 Hoosier A6's with +38 offset on a 15x7 rubbed. They are about as wide as any other 225 on an 8" wheel. IMO.
Old Oct 3, 2007
Boggie6868's Avatar
The offset on the new wheel is +36. I also got 7.5mm spacers. Hopefully the studs won't be a issue. They sound like they are expensive.
Do you know if using spacers will have an adverse effect on the suspension? What kinda of spacers do you suggest?
Thanks!
Old Oct 10, 2007
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
It is not recommended to use spacers. Putting them there allows for improper torquing, which can cause bad things to happen, like your wheel falling off.
Old Oct 10, 2007
Boggie6868's Avatar
No need for spacers, the rims and tires fit on there fine.
Old Oct 10, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Throw it into an uphill turn on-camber at about 80 MPH and see if they still fit fine.... you're going to need to put the suspension to its extremes before you can really be sure that they fit. R compounds stick A LOT harder than street tires... your suspension will move to limits you didnt know it could.
Old Oct 11, 2007
Boggie6868's Avatar
Thanks for the heads up. I haven't pushed the car yet. I didn't get the tires shaved so I'm going to drive around on them a bit and let them wear down. Plus I'll kinda get the feel of driving a car with different offset wheels. I can already feel a difference in steering.
As for the rubbing, hopefully the correct alignment will take care of any rubbing issues. Wish me luck.
cmart1209
May 29, 2015 04:52 AM
AlexLx
Apr 17, 2002 03:14 PM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
