Not sure which place to post this thread
Old Mar 31, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Ok so, I have googled and watched countless 3D presentations on how a DOHC 16 valve engine works, I mainly only watched it because I’m about to do an engine rebuild on my 03 Civic Lx. But what has me confused and what most of my mechanic buddies and I can’t answer or find any video representation of is how a SOHC 4 cylinder 16 valve engine works (I.e like mine) I understand the loves of the camshaft control the valves and the timing belt is how the camshaft stays in time with the rest of the engine. But does anybody know how the camshaft is able to perform that work load? I know the lobes are what actually move the valves but I can’t wrap my head around how it’s able to move all of them (even though it isn’t all 16 at once) Anybody have any video or a way to give me a visual of how it does it? I just want to be able to understand my engine and how to does what it does before I crack it open for a big rebuild and general overhaul of the entire vehicle.
Old Mar 31, 2018
Re: Not sure which place to post this thread
Honestly, if you wanna see how it works, pull your valve cover and have someone rotate the crank shaft (counter clockwise, via the crank pulley bolt -- you won't loosen it, that takes quite a bit of effort). It helps if you pull your spark plugs, so the person rotating the crank doesn't have to fight compression strokes. The only thing you won't be able to see is how VTEC works, but you'll get a good idea of how a single cam is able to sequentially open valves (spring pressure closes them) via rocker arms and different lobes on the cam.
It's been a minute, but if I remember correctly, the firing order is 1-3-4-2, cylinder 1 being closest to the timing belt
Old Mar 31, 2018
Slumpertcivic's Avatar
One cam, 16 lobes.
rocker arms are bent so that two in middle go together bending away from each other and two on outside bend inwards to keep it very compact.
Old Mar 31, 2018
Thankfully mine is Non VTEC, not that I have any issues towards a VTEC. But I have heard that it’s a little more difficult to rebuild the engine and stuff. I love my vehicle I do basically all the work except transmission work as I am not trained in that area. The car in subject has 300,000 original miles on a factory engine so I decided to spend my money wisely and possibly save myself a lot of headaches and do a complete rebuild and resurfacing to the block and head (which I am questioning how hard it is to disassemble and reassemble due to the camshaft and such) just wanted to better understand how she works before I tore into it
Old Mar 31, 2018
Originally Posted by Slumpertcivic
One cam, 16 lobes.
Thanks man! I do appreciate the answer. I was actually really stumped trying to think it through on my own
Old Mar 31, 2018
You don't have to disassemble much to see how it works. You don't even have to replace any gaskets.
-Remove plastic wire cover, unclip all 4 coil packs and remove (held down by a 10mm acorn nut)
-Unbolt wire brackets/holders from valve cover (IIRC, there's 3 10mm bolts holding wires and brackets down?)
-Use a pair of pliers to remove breather hose clamp from valve cover. Disconnect breather hose from valve cover.
-This step is optional, but it helps get everything out of the way: Unbolt wire from alternator (positive lug). At this point, entire wire harness should be able to pull away (towards the passenger side), completely out of the way of the top of the engine.
-Unscrew the 5 bolts holding the valve cover on. Pulls right off. If you didn't remove the wire from the alternator, you'll have to do a bit of tetris work to get that thing out while navigating around the wire harness.
At this point, like I mentioned above, remove the spark plugs and have someone rotate the crank manually, counter clockwise (19mm socket, helps if you remove driver's side wheel. There's a little hole in the fenderwell lining you can use to access that bolt).
Now, disassembly of the engine isn't really hard at all. Just time consuming and lots of parts. If you know how to turn a wrench, you can do it. In fact, I did it back in.. 2012 or so, and it was the first engine I had ever disassembled. I literally took the entire engine apart so I could being the block (by itself) to a machine shop to give it a once over. Don't rush, keep yourself organized.
Did this all in my dad's garage, no less.
Crank shaft, pistons, oil seal
bare block, with the exception that I left the water pipe, PCV chamber attached
I labelled the crap out of everything, had about 3 or 4 tables for parts and tools. Haynes manual helped out a metric crap ton, especially with torque values
Old Mar 31, 2018
[img]https://i.imgur.com/igldFlW.jpg[/img
[img]https://i.imgur.com/y9kGdq7.jpg[/img
Thanks! You actually helped me in a lot of ways. I actually catch grief for owning a Honda and refusing to put louder exhaust and bigger wheels on it but I love it the way it is. I currently still get strange looks from everybody considering I’m one of the only females in my family and where I live that isn’t afraid to get dirty and most importantly learn. I’ve been working on cars since I was about 7. And since then they have always fascinated me. I plan on buying the Haynes manual on it just because torques specs are key to engine rebuilding and making sure things seal right. The only thing I’m currently afraid of is my transmission it has 300,000 miles on its factory most of the car is factory except small minor things. I know better than to ever flush a transmission and I’m not sure if I’m mentally able to rebuild it. But I know to put genuine Honda ATF in it, I’m just afraid that since it’s never been drained and changed that the new fluid might actually make 1 of the 40 bazillion clutch plates slip and I don’t think I’m mentally or monetarily ready to replace it or have it rebuilt for me. The engine I’m fairly confident with rebuilding and I’m confident with the machine shop I’ve chose to do the resurfacing and boring of the block and head. It’s just the transmission that now has my nerves on edge. I know enough about a transmission but not enough to rebuild it myself. I know how they work but they are very electrical and mechanical. And it’s tedious. But once I rebuild the engine and clean it and do some general upkeep this little car (minus paint job) will look almost brand new and run 10x smoother I hope.
Old Mar 31, 2018
Flush with chemicals and machine is always strongly discouraged.
Simple ATF drain and fill is basic routine service and should not cause problems regardless of mileage.
Simple drain and fill with proper fluid is always encouraged.
You can repeat the process a few times to get the majority of the old fluid exchanged out of there too.
Any problems that arise were probably already present before fluid service. With 300k+ original miles it could poop out at any time LOL
Old Mar 31, 2018
Lol I’m fully aware of it, notes why it’s a nail bitter to me. I’m currently having a coolant issue and I’ve troubleshot coolant issues and overheating before but this ones got me confused. Considering I’ve replaced my radiator a week ago and it’s holding, or I pray it is. I don’t even know.
Old Mar 31, 2018
Read the thread about overheating common causes
Old Mar 31, 2018
https://www.civicforums.com/forums/3...reference.html
Old Apr 1, 2018
I fixed it! Took it to shop, I overfilled reservoir caused too much pressure. Very happy!
Old Apr 1, 2018
You had better keep a close eye on the fluid levels from now on.
Overfilling the reservoir can make the coolant spew out as the engine warms up to operating temperature....because the antifreeze in the engine and radiator expands as it's heated.
Then as the engine cools down, the reservoir level should drop and return to its original starting point fluid level
If the reservoir overfills while the radiator level drops, then the system isn't working as intended.
Old Apr 1, 2018
I generally do, but I didn’t think about the reservoir, I didn’t know that over filling it would cause to spew out. I know now though
xdee716
Oct 2, 2006 09:36 AM
ImPulse
Feb 28, 2004 03:50 PM
ruffles3
Sep 12, 2002 07:47 PM
