Newbie looking at a high mileage civic
Old Jun 26, 2013
Jared583's Avatar
Jared583 is an unknown quantity at this point
Hey all! I'm a newbie here looking at a 2001 civic with 240,000 miles. The car looks and runs good I just wanted some input from you guys before I pull the trigger. There are zero maintenance records on the car other than the last oil change. I do plan on doing a timing belt and water pump right away if I get the car. I have owned Hondas in the past so I'm not a total newbie just to this gen. What can I expect with that many miles?
Thanks!
Old Jun 27, 2013
GolNat's Avatar
Prelude Owner
Re: Newbie looking at a high mileage civic
Is it an automatic?
If your getting it for a great deal then just put a little work into it and you will be in good shape. Timing belt, water pump, possibly head gasket.
Old Jun 27, 2013
Jared583's Avatar
Originally Posted by GolNat
Is it an automatic?
Thanks for the reply. It's a 5 speed
Old Jun 27, 2013
GolNat's Avatar
Prelude Owner
I would also check the clutch to see of its slipping any. It's probably the 2nd clutch maybe 3rd.
Old Jun 27, 2013
Jared583's Avatar
I'll be going to test drive it today or tomorrow and if everything checks out I'll probably bring it home. I just wanted some input on what I'd expect to replace with that many miles
Old Jun 27, 2013
Mad Dog Tannen's Avatar
Inspect and touch everything under the hood and underneath the car. If you find something warn or broken you can use it as a bargaining chip. Look at all rubber parts for deterioration. Check all fluids for signs of wear or failure.
I also recommend doing a compression check for added insurance.
Test drive it when it is cold, but let it warm up fully. Feel the exhaust manifold, if it's warm than come back when it's cold or walk away. A lot of potential issues can be apparent on startup and warming up!
Good luck.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 06:58 PM
Thees1
Apr 14, 2015 08:23 AM
