Info on performance mods
Old May 30, 2008
513steve's Avatar
513steve will become famous soon enough
Arrow Info on performance mods
Im tryign to find feedback on a few parts Im lookign at getting. I have an '01 civic dx 2dr. As of now it has a Fugita CAI and an Apexi WS2 catback on it. The next couple of mods I am looking into are an exedy stage 1 organic clutch(08801A), and an exedy lightweight flywheel(HF501). I woudl also do a B&M shifter and a braided clutch line, is it worth it to spend the $600-$700? or would I be better off spending it on a header and pulleys? or doign a cam and cam gear? Any info would be greatly appriciated.
Old May 30, 2008
TRIZ's Avatar
Re: Info on performance mods
is there anything wrong with your current clutch? If not, its perfectly fine and wait till you have more power and your clutch starts to go. A header... wait on it, theres supposed to be one coming out by magnaflow for your application soon, but it hasnt dropped yet that I'm aware of- or it has rumored to have, but nobody has any info on it yet or pictures. A cam with def give some kick to your accelerator- a crower stage 1 wont require any other mods. A cam gear would allow you to adjust timing by a few degrees. Look at the exhaust FAQ link in my sig for what you should do with your header/exhaust if the magnaflow never drops or drops and turns out to be shitty. Hope that helps ya.
Old May 30, 2008
513steve's Avatar
Ok cool, well, th eclutch isnt bad. but, i did smell it the other day when I downshifted and gave it hell, so, Id rather upgrade now with it. I did read about the magnalow on here a few days ago so, Im waiting on it. Thanks for the info man.
Old May 30, 2008
513steve's Avatar
http://www.raceeng.com/p-7027-crwr-camd17a2stage-1.aspx
is this the cam your talkign about? Also, any recomendations on cam gears? AEM seems to be the only one I can find.
Old May 30, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
suport local vendors
http://www.dezod.com/cat_camshafts.cfm
stage one cam no need for cam gear or valve springs/retainers.
SS clutch lines? link?
Old May 30, 2008
513steve's Avatar
Thanks fo rthe link man, Ill check it out, Ill try to find the SS line again, I ordered it when I bought the car an dhave yet to put it on.
Old May 31, 2008
513steve's Avatar
http://redhat3.admarkonline.com/nipp...ct.phtml?p=785
I used the sam ebrand on both of my rx7's, got much firmer clutch pedal feel, plus it looks awsome under the hood lol, hope this helps.
Old Jun 2, 2008
02BLKCIVIC's Avatar
thats cool as hell^
thanks
Old Jun 2, 2008
513steve's Avatar
No problem at all
Old Jun 2, 2008
RallyeRedRider's Avatar
RallyeRedRider has a little shameless behaviour in the past
By a "much firmer pedal feel" do you mean that the clutch is more difficult to push down? I don't see why that would be desirable unless your trying to give your left calf a work out. It's not like brakes which take feeling and partial application, the clutch is either in or out.
Old Jun 3, 2008
speedfoos's Avatar
I like that clutch and FW setup you're talking about and ran it for about 6 months before strapping the turbo on my Civic's nose. Buy it, you'll like it and notice a positive performance difference.
Old Jun 5, 2008
513steve's Avatar
Its liek braided lines, it makes it firmer, and better engagement. I have used one on all but 1 of my cars.
theteju
Aug 5, 2015 06:59 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
