De-restricting a d16a
Hi iv have just recently bought my civic coupe d16a and it seems to be restricted to 4/5 rpm in 1st to 3rd gears. Iv had a jap import before and know they are restricted in those gears but am unsure of how to de-restrict it on one of these. Could someone please help me? Thanks.
Re: De-restricting a d16a
I bet the cat is clogged. Drop the exhaust and test drive it.
The civic revs ok in 1st but in 2nd only revs to 5500 rpm. And round about the same in 3rd :/ i thought with it being an import it might have a restrictor onit. So u think it may be the cat?
If it has VTEC code set, it may limit RPM too. If it has VTEC.
If you can't reach redline @ WOT in gear -- but it will rev higher by backing off the throttle a little, then clogged exhaust is my first thought. Usual suspect would be the cat here.
I might think differently if I was to actually experience what you are trying to explain though.
HTH
in a honda, there *might* be restriction if it is not in gear. our computers are not smart enough to change limiters by gears, not even think it is necessary. If you talking about a turbo, it might have been the case in that glanza something you are mentioning (no idea what that car is, though, so like mentioned above, which country are you from?)
Im from the uk. Yeah my glanza that i had was a 1.3 turbo and i knew alot about it, but like i said im new with honda this is my first one. I just thought with it being a jap import it may be restricted like my glanza was. When in neutral it doesnt redline either but u say thats normal for a honda?
I will try letting off the throttle a little and then putting back on and see if that makes a difference and if it does like u say it will probs be the cat thats clogged.
Its the single vtec. Not actually classed as a vtec i dont think but myaswell be as the valve opening does the same thing.
I know most of Hondas later automatic trans cars have a lower rev limit when in neutral or park than they do when in a gear.
I wasn't sure if a manual trans car uses similar strategies.
I have no clue if any of this would apply outside of North American markets, but I'd expect it would.
sdaidoji
Feb 4, 2012 07:35 AM
