1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Weak Headlight Output
Old May 26, 2012
rmdt4's Avatar
rmdt4 is an unknown quantity at this point
I have a 95 Civic sedan. The drivers side headlight is not as bright as the passenger side. I have replaced both bulbs with news ones.
I cant' figure out why they are different. They are factory headlights.
I did have a fender bender on that side. Could that effect the output?
Is there anything inside the headlight assembly that could have shaken loose?
Any help would be great.
Old May 26, 2012
lazlong's Avatar
Re: Weak Headlight Output
Check for battery voltage at the light socket. If you're getting battery voltage then it's a bad ground- which is under/behind the headlight.
ThatGuy913
Sep 28, 2015 05:35 PM
Skunkone
Sep 24, 2015 04:38 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
