1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 civic ex sedan (need help))
Old Aug 27, 2011
lilsimba1992's Avatar
lilsimba1992 is an unknown quantity at this point
i just got my civic with 170k miles on it
everything is stock!!
whats the first step to working on it? i dont want a ricer so ima focus on whats under the hood first rather then the look !! help!!
i need to know what i should check out on it or what i should fix on it!!!
Old Aug 30, 2011
lazlong's Avatar
Re: 1995 civic ex sedan (need help))
I don't understand. Do you want upgrades or are you just looking for what maintenance items need to be done?
Old Aug 30, 2011
before i upgrade anything i want to fix what should be messed up on a car that old u follow me? then i want to upgrade
Old Aug 30, 2011
lazlong's Avatar
Do you have an maintenance records?
Basics first: Oil change, air and fuel filter changes, change plugs and wires, coolant flush (if it needs it), check the ATF if it's an auto (if you don't know when the ATF was changed last then don't touch it if it looks/smells bad), replace belts if they are worn.
Advanced: check engine mounts, check valve clearances, replace timing belt/tensioner and waterpump, check wheel bearings, check steering (tie-rods), check the whole suspension (push one end of the car down and it should go down, come up, then settle- no more. or if it pops/rattles).
EDIT: Look to MelJ's sig for the service manual.
usajags84
May 10, 2015 08:11 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dano2005
Apr 14, 2015 01:58 AM
aus10
Apr 13, 2015 09:26 PM
