1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
What Engine is This???
Old Mar 18, 2011
86_Civic_Si's Avatar
86_Civic_Si is an unknown quantity at this point
Exclamation What Engine is This???
I just purchased this Civic yesterday--my first. 1986 Civic Si. I have to replace the timing belt (and such) ASAP, but don't know what engine this car has in it! The odo reads 327K and I was told the engine had some work done to it, so I'm assuming it's not the original, but do not know.
It's a SOHC, but I can't find the block code plate where others have said. I found an ID stamped into the block to the right of the timing belt that says "FW1051" but have not found any information on it.
Can someone help me? I need to know so I can go buy parts for it today.
I will post photos of it in just a moment...
Thanks in advance,
Sam
Old Mar 18, 2011
lazlong's Avatar
Re: What Engine is This???
Cool, I LIKE! The last time I saw that model we got rear-ended by a Camaro.
If it's the original engine it has a carburetor. If it has fuel injection it's a swap. If it's the original engine: Go to the autoparts store and ask for a belt for an '86 Civic SI (it's a 1.5L). Or go to the dealer. Or here: http://www.hondapartscheap.com/southbay/jsp/home.jsp
If it's fuel injected: Look between the distributor and exhaust pipes and it should be stamped on the little flat place of the block.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
