1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Quick question before lunch.
Old Feb 3, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
If I am starting to leak a little oil form the bottom end. Is it difficult to chance the oil pan gasket with out taking the motor out. If its going to be hard, Ima just take the engine out and redo the entire bottom end. But Id rather just fix the leak as of now.
also, I am getting a stage 2 cam that is in a head already. Is that not smart to use a diff head, that has a stage 2 cam, or no different than any head swap. didnt know if maybe the previous engines compression could have messed it up, or putting it on my engine w/ its compression. Do something.
I just dont want to take the cam out of that head & have to reset it.
Old Feb 3, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Re: Quick question before lunch.
As for your first question, you dont need to remove the engine to fix a leak, be it an oil pan gasket, crankseal (unlikly) or rear main seal. I suppose it depends where the actual leak is coming from...but still.
Old Feb 3, 2011
Bringer Des Blutes
Alright cool, I never changed one on a 4cyl before, Only Chevy small blocks, Which 90% of them need to be pulled, or at least motor mounts broken loose. Gonna just get a new oil pan & Gasket, I have bottomed out quiet a few times, May have warped the pan a little. Which yeah, the oil is coming from the side of the pan, no where else.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
