1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
94 Civic DX starting problems, need help!!
Old Jan 11, 2011
Shadowjedi's Avatar
Shadowjedi is an unknown quantity at this point
A couple of weeks ago driving my 94 civic DX (99,500mi - 1.5, 16 valve engine) on the freeway the car died on me. I found I had a bad distributor. I found a replacement from a U-Pull-It place. I removed the old distributor and as I was getting ready to replace it with the other one (also from a 94 civic DX - w/1.5 16 valve engine) I noticed the distributors where not the same (see attached photos). The distributor in my civic had a square type box with a positive and negative connection with a stem on it with a spring on the top of the stem. Figuring this was needed I rewired the replacement distributor to have this box in the replacement. I attempted to start the car after replacing the distributor (i also got new plugs, wires, cap and rotor). Car tried to start a couple of times then when completly dead (no start, no lights no nothing). I figured it was a fuse, so I check fuses and I did not find any bad fuses. Assuming the square box from the distributor was the problem, I removed it and rewired the replacement distributor back to its original form. Car still has no power, no lights, no nothing. Am I missing a step somewhere? I'm a house mechanic (which is to say I am no mechanic at all) but I do learn from trial and error (lots of these, lol). I cannot get the car any power at all. Any help will be greatly appreciated.
ID:	80028   Click image for larger version
Old Jan 11, 2011
Shadowjedi's Avatar
Re: 94 Civic DX starting problems, need help!!
On the photos below, the distributor on the left is from my civic. The distributor on the right is the replacement .
Old Jan 11, 2011
Shadowjedi's Avatar
OK, found a bad fuse (must have missed it) but care will not start, does anyone know what the square box in the distributor is? Do I need it or can I do without it.
Old Jan 11, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I am not positive but I believe that would be the coil pack, and if it is, it is definitely needed for the car to run.
Old Jan 11, 2011
lazlong's Avatar
It's the coil, and no, it won't run without it. #12: http://www.hondapartscheap.com/south...t=0&quantity=0
Old Jan 12, 2011
Shadowjedi's Avatar
thanks for the info.
CarStuff
Dec 6, 2020 12:52 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Braun
Apr 23, 2015 09:03 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
