1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
throttle lever/cable? problems!!!
Old Nov 5, 2010
slammdEJ8's Avatar
slammdEJ8 is an unknown quantity at this point
Exclamation throttle lever/cable? problems!!!
i have a USDM GSR SWAP. sometimes when your driving and hitting the gas, when you let off, the throttle lever gets stuck and stays at 2000 rpms. you have to just tap the gas pedal and it will be fine and go back to normal idle. anyone know why this is happening and wut i can do to fix this? thanks
Old Nov 6, 2010
lazlong's Avatar
Re: throttle lever/cable? problems!!!
Work the pedal by hand and see if the return spring on the pedal is working properly. Then check the cable itself and see if it's catching anywhere or needs to be lubed.
Old Nov 6, 2010
MelJ's Avatar
Trance Addict
My car did something like that, except that the throttle response was delayed. My problem turned out to be an out of spec throttle cable. If that's the case, it's a 5 minute fix....if that. If the cable needs grease, I think white lithium might work well.
Old Nov 6, 2010
slammdEJ8's Avatar
ok thanks. you have details on how to fix and lube it? would cleaning out the throttle body do anything? and cleaning the throttle lever?
Old Nov 6, 2010
Mad Dog Tannen's Avatar
Sounds like the cable. I wouldn't use that white lithium grease, that stuff is crap. I would get a new cable and lube it up well just to be sure. But lubing it will probably fix it. You can also get a stronger return spring. And make sure its not catching on anything. It may have been routed badly during the swap, with harsh angles that are causing friction.
Could be the throttle body also, but not likely. It wouldn't hurt to clean it out and inspect it though.
Allecr3
May 22, 2015 01:24 PM
Shakzhussain
May 17, 2015 12:03 PM
tylerginevan
Apr 27, 2015 12:29 PM
tkcne
Apr 18, 2015 02:33 AM
antidote11
Jan 6, 2002 10:22 PM
