1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
92 SI hatch; Help?
Old Aug 23, 2010
TINOO's Avatar
TINOO is an unknown quantity at this point
92 SI hatch; Help?
Well I have a 1992 Civic hatchback SI and my problem is: sometimes the car starts fine, but after I drive it around for a while or a bit, and park it and leave it there and try to start it again, it won't start. Me and my friend were thinking maybe it's the ECU ? we moved it around somewhat and tap it a bit and try starting it and it worked. I'm not sure whats the problem, sometimes it starts and sometimes it doesn't. can anyone help? or know what might be the problem? I would really appreciate it.
Old Aug 24, 2010
Civvyftw11's Avatar
Civvyftw11 is an unknown quantity at this point
Re: 92 SI hatch; Help?
When you turn the car on check to see if the fuel pump is priming, there should be a whirring noise when you put the key into the ON position, if the fuel pump is priming and the problem occurs only when the car is warm, take your main fuel relay out and test it.
Old Aug 28, 2010
TINOO's Avatar
oh, i had someone look at it and he said it was because of the ignition coil.
Old Aug 28, 2010
crossfire's Avatar
crossfire is an unknown quantity at this point
Well! It could be the coil but most of those problems came to be the fuel main relay located under the drivers side next to the fuse panel.
Hatchness
Sep 14, 2015 09:02 AM
yyyktk1
Sep 12, 2015 04:02 PM
Monty022581
Aug 31, 2015 08:32 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
