1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Now onto the A/C issues...
Old Jul 13, 2010
95EX's Avatar
95EX is an unknown quantity at this point
I know a 1.6L engine will pull back slightly when the clutch engages on your A/C compressor, but my engines PULLS hard, even on the highway. When im around town going slow, when the compressor engages it can pull the car so hard i need to give it half throttle just to get going.
IS this a bad clutch problem or something deeper? Could this also be the culprit to my air not being cold enough. Although in the early morning and at night the A/C is ice cold, but during the hot day (miami) its not so much cold.
Old Jul 14, 2010
jworth's Avatar
jworth is an unknown quantity at this point
Re: Now onto the A/C issues...
I don't think it's a clutch problem. Sounds like the compressor is working too hard. The question is why. There are only 2 things that I can think of. One is that maybe the bearings are going bad. I sort of doubt that though. The other is that there is some kind of restriction in the system. There is a high-pressure valve on the compressor. If the pressure gets too high, it'll blow.
Just rambling here to give you something to think about.
Old Jul 15, 2010
95EX's Avatar
i thought about the bearing too...how do i oil them? I thought there was maybe some oil in the r134 or am i wrong?
The a/c just doesnt get cold enough so im thinking the compressor is somehow going bad and not spinning fast enough to cool the car.
Old Jul 16, 2010
jworth's Avatar
Some refrigerant has oil in the charge, some doesn't. The oil goes in the same way as the refrigerant charge. Do you have gages to check the pressure? You can get a refill kit that has a hose with a gage that'll give you some idea if there's pressure in there. That's a cheap start.
Old Jul 18, 2010
ralph50's Avatar
ralph50 is an unknown quantity at this point
There is not much you can do about it except wait till it dies.
You can probably buy some time with an a/c oil charge.
As compressors get older the clearances inside allow the compressor which acts like one big screw to wobble.
As they get older you can hear noises and small rattles coming from the inside.
The fact that you feel your car slow down means that there is alot of internal friction within the compresor.
Its just a matter of time before it dies.
From my experience a/c compressors don't last much longer than 120K or 130K miles.
h4ldol
Apr 24, 2017 08:16 PM
jtcavey
Sep 30, 2015 02:18 PM
JMKendrick
Sep 16, 2015 06:17 PM
MichaelLW
Sep 14, 2015 07:15 AM
andyandyy
Aug 4, 2015 06:37 PM
