1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1995 Civic EX with a surging idle.
Old Jan 28, 2010
brian0128's Avatar
brian0128 is an unknown quantity at this point
Ok, this is not my car, it's my ex wife's but she needs help and I said I would help her out. She has a 1995 Civic EX with 233,000 miles on it. The car has a surging idle that goes from 1000-1500 rmp whenever the car is at rest with the clutch in or out. The check engine light came on for the first time yesterday.
I took it to the local parts store but this one doesn't read codes anymore so I have to find another one tomorrow. The guy there said it was a vacuum leak and I searched to no avail on the intake hose. Any ideas what would cause the surging idle? Also, I did a search on idle and saw alot of posts mentioning relearn the idle but I couldn't find one explaining how to do it on a 1995 Civic. Can anyone point me in the right direction?
Also, with this many miles, does anyone recommend any additives like Lucas or Restore for the engine oil?
Sorry Mods, noticed that this is in the wrong section. Can I get it moved?
Last edited by brian0128; Jan 28, 2010 at 08:03 PM. Reason: Noticed that thread is in wrong section.
Old Jan 28, 2010
Re: 1995 Civic EX with a surging idle.
usually surging idle is caused by bad tps (throttle position sensor) on the throttle body. meaning the whole tb will need to be replaced. usually pretty cheap for a used one on ebay $50-100 and clean it up before installing. thats assuming you dont have any vacuum leak tho. with that old of a car, one of the hoses may be worn out. and check pcv valve too while youre at it.
Old Jan 28, 2010
brian0128's Avatar
Thanks for the quick reply. I'm only finding ones on ebay for an AT transmission. I will try the local breaker yard tomorrow to see what I can find.
Old Jan 29, 2010
yeah dont get the auto tb if you have a manual, it wont work.
Old Feb 17, 2010
brian0128's Avatar
I still haven't found one for sale, but a guy at a local shop told me to check the IAC valve. How would I do that?
Old Feb 17, 2010
its the piece that has two coolant hoses going into it. usually bolted to the throttle body or intake manifold and has a few screws or bolts holding it on. you can clean up the insides with carb spray cleaner.
beneditti
Jan 15, 2016 12:31 PM
F1wanabe
Apr 27, 2015 11:06 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
silvervtec01
Nov 4, 2001 06:56 PM
