need injector help on motor swap
Rep Power: 0 need injector help on motor swap
Hi all, new to forum.
I recently replaced a D16Y8 motor from a 1996 into a 2000 ex. car runs fine but seems like it takes forever to rev up. Seems very under powered. I was wondering if they run different injectors. I have old manifold from original 2000 motor. Can I just swap injectors?
The only CEL I have is the P1457 i'm chasing down.
Car seems like a real turd power wise.
thanks
Jim
thanks
Jim
Re: need injector help on motor swap
Assuming the 1996 and 2000 were both D16Y8 VTEC....the parts catalog shows different part numbers for the fuel injectors --- but I have no specs for flow rate. Swap them and see what happens?
Check cam timing?
Check cam timing?
What happened to the old engine?
Was there a lot of misfiring when it died? Misfires and dumping unburned fuel can kill a cat quick.
WaryDriver
19
11-29-2015 07:04 AM
steve6
11-22-2015 08:18 PM
sruger
11-15-2015 02:52 PM
beanhead
09-24-2015 12:04 PM
