Over heating issues
Old Apr 15, 2018
Kevin98civic's Avatar
Kevin98civic is an unknown quantity at this point
Over heating issues
My 98civic started over heating last week. What happens is the temp gauge gets close to the H but usually goes back to normal when I turn on the heat and the fan on high. I thought it was a thermostat so I put a new one in yesterday. The problem still exits but now turning the fan and heat on isn't bringing the temp down. I welcome any ideas
Old Apr 16, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Re: Over heating issues
check for any coolant leaks, could be a radiator problem. But it sounds like your engine coolant temp sensor is bad, that’s what turns your fan motors on to cool it. Or a fan relay or motor
Old Apr 16, 2018
Over heating
Thanks. I will flush the radiator asap... Both fans work. I saw the one come on and the other came on after i turned on the heat
Old Apr 16, 2018
Re: Over heating
you can try flushing your radiator, it’s either your radiator or maybe a water pump issue
Old Apr 16, 2018
I am flushing the radiator now. I have the flush cleaner in and water in it now. Been running the car for about twenty mins... Getting ready to drive it a few miles. So far the temp is normal in the middle of the gauge and I have both fans running
Old May 6, 2018
JesusWoreNikes's Avatar
JesusWoreNikes is an unknown quantity at this point
Walker Products 211-1015 Engine Coolant Temperature Sensor https://www.amazon.com/dp/B00WCCLX2I?ref=yo_pop_ma_swf
evilrod
Oct 16, 2014 09:23 PM
boosted1.7??
15
May 1, 2010 07:29 AM
theessence85
Feb 19, 2008 05:23 PM
DropDownCivic
Engine Swaps
Nov 16, 2007 06:21 PM
CoolMD
Dec 6, 2001 10:40 PM
