Code p1607
Old Apr 15, 2018
asc2000's Avatar
asc2000 is an unknown quantity at this point
Code p1607
I have a 2000 civic ex with a JDM B16b ctr swap. I am using a 99-00 si harness and matching 99-00 si (P2T) ecu. I need to pass NYS inspection but I have a cel for code p1607 PCM internal circuit malfunction. What is the reason for this code? After I pass NYS inspection I will go back to using the JDM (PCT) ecu.
Old Apr 15, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Re: Code p1607
Faulty PCM or ECM. That’s what the code means.
Old Apr 15, 2018
asc2000's Avatar
Re: Code p1607
Would a PCM reflash at the dealership fix the issue. Or should I trade ecu with someone and see if that works.
Old Apr 15, 2018
Re: Code p1607
Dealer can't reflash.
Swap first to test with a known good ECM.
Hondaguy72
Mar 27, 2018 05:50 PM
Ski_Lola
Aug 15, 2011 10:50 AM
bellabri287
Nov 18, 2006 10:58 PM
caveman_0_1
Dec 31, 2005 06:57 PM
SODJAZERO
Jun 21, 2005 02:50 PM
