Lower end block swap D16a and D16y8
Old Jun 10, 2016
2210a's Avatar
2210a is an unknown quantity at this point
Picked up a free 98 Civic EX D16y8 with bad compressions in cyl 2 and 4 and picked up a good D16a engine for 50. Would be possible to just swap bottom ends and call it good? Just looking to get it back in good running condition without having to tear into y8.
Pick of EX
Old Jun 10, 2016
Re: Lower end block swap D16a and D16y8
Do you know WHY it has low compression?
If the low compression is due to valve problems (typical problem), swapping the short blocks won't help that because you'd be reusing the original head.
Old Jun 10, 2016
2210a's Avatar
Thanks for the input. Havent done any work yet but the tear down begins next week. Ill be sure inspect valves.
Old Jun 10, 2016
If you did a compression test and found the bad results that way, the next step would be a leakdown test (cylinder leakage test) to determine exactly where the leakage is going.
It's tough to do this test after you've taken the engine apart. DO all your testing before you take stuff apart, so you know exactly where and what you should be looking at once it is apart.
dsokolowski
Nov 8, 2015 10:34 PM
CompaHayden
Nov 1, 2015 06:37 AM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
WeRkX
Nov 1, 2001 10:33 PM
