Silly Question about Dip stick
Old Apr 3, 2016
EZRYDER's Avatar
EZRYDER is an unknown quantity at this point
Ok So i'm new to Civic's, I go out to do a routine check of the oil, pull out the dipstick, it looks like it needs oil, So I wipe the dipstick and put it back in and then it looks like it needs oil again. I go to start to car and then It shows me it doesn't need oil. But then I put the dip stick in again and it shows me it does need oil then for one last check I put the dipstick back in and check again and it tells me I don't need oil.. What gives. My other car gives me persistent oil readings. So is this normal or??
Old Apr 3, 2016
Re: Silly Question about Dip stick
What does your owners manual say?
NO NO NO.
Check oil with the engine OFF.
Old Apr 3, 2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Ezone, he's talking about the transmission.. the short stick.
Old Apr 3, 2016
I didn't read where the OP mentioned 'transmission'.
No matter, the transmission is also checked with the engine OFF...as described in the owners manual.
Now I wonder if the oil in OPs other car is very low or overfilled.
Old Apr 4, 2016
RIPSAW's Avatar
His other car is a Ford?
Old Apr 4, 2016
EZRYDER's Avatar
I initially checked the oil with the engine off. I checked it three times with three different results. I think I solved the problem though. The manual says to let the dipstick sit for a few minutes before checking again.
Old Apr 4, 2016
mikey1's Avatar
how hard can this be?
drive the car to operating temperature,
park car on level surface,
shut engine off,
wait 2-3 mins,
remove oil dipstick,
wipe oil dipstick off,
insert oil dipstick,
remove oil dipstick and look at reading,
oil level in between low and high marks = do nothing
oil level lower then low mark = add oil till it reads between high and low marks
if you are not capable of such task, never touch your car again
Old Apr 4, 2016
EZRYDER's Avatar
shut engine off,
wait 2-3 mins,
Im capable of "such task" just odd having it show two different readings, Like I said i've never had a car show me that before, So I asked about it. But whatever..
Old Apr 4, 2016
mikey1's Avatar
the level may vary SLIGHTLY if the engine/oil is warm or cold,
best to take the reading warm IMO
R Steele
Oct 22, 2015 05:09 AM
CraigW
Oct 13, 2015 08:56 AM
Enriquepd
Oct 7, 2015 05:43 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jsmithe2010
Regular Maintenance
Sep 25, 2015 08:15 PM
